Armstrong Introduces the Self-Regulating Variable Speed Fire Pump
Armstrong Fluid Technology has unveiled its industry-leading, self-regulating variable speed fire pump which, in addition to new safety benefits, also holds the distinction of being the first fire pump to meet NFPA-20 (2019 Edition), Section 4.8 standards.
“The new Design Envelope Fire Pump will provide safe, reliable performance in fire suppression systems, along with complete transparency into the operation of the pump. The Design Envelope Fire Pump also makes fire suppression systems that require a variable speed approach more affordable for contractors and building owners, as it enables a more cost-effective design for the fire sprinkler system.” said Steven Baird, Marketing Manager – Fire Products at Armstrong.
Baird stated “As the first fire pump that offers integrated variable speed, the new Design Envelope Fire Pump provides critical operating data that is always accessible via the built-in performance management feature. This real-time information will alert users to changing conditions in the system that might affect operation or maintenance priorities.”
The key performance data assessed includes:
- Pump operation history
- Jockey pump run time
- Test mode visual indicator
- Storage tank water-level indicator
- Suction pressure levels
Based on its capability to deliver precise pressure and flow as required by a sprinkler system, the new Design Envelope Fire Pump provides greater project flexibility, substantially reduced building costs, valuable space savings and reduced maintenance costs.
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
