Buderus SSB Industrial Boiler
The Buderus SSB Industrial Boiler is designed for commercial space heating and domestic hot water, this boiler’s integrated cascading allows users to easily quadruple output if desired. The units are available in 798 MBH and 1024 MBH standalone units, or a 1024 MBH cascading unit, designed to effortlessly cascade to meet demands up to 4096 MBH, making it an ideal solution for applications such as schools, hotels, office buildings and warehouses.
Engineered with the contractor in mind, the Buderus SSB Industrial Boiler models’ single-platform design and compact footprint allows for easy startup and install location flexibility. In addition, the unit features all key connections, including exhaust, intake, supply, return and gas on both sides of the units. The unit also has removable panels on all four sides for easily accessible components.
This industrial boiler features dual heat exchangers for increased capacity, which includes two 316L stainless steel watertube heat exchangers with easily accessible supply and return connections. The patented heat exchanger design provides consistent combustion for longevity and durability, with precision welds for increased reliability. The boiler can achieve up to 96.8 percent thermal efficiency with up to 10:1 modulation on a single unit and 40:1 modulation at maximum-cascaded capacity.
The boiler works with multiple building communication options, including Modbus, BACnet and LonWorks. It includes an on-board control with a 7-inch external touchscreen display to streamline common applications like connection to a room thermostat, system monitoring, outdoor reset and domestic hot water priority standard. It also features an internal HMI screen that provides system level parameter adjustment.
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
