Caleffi Introduces Balancing Recirculation with THERMOSETTER™
Introducing the THERMOSETTER™ adjustable thermal balancing valve used for automatic balancing of recirculation loops in domestic hot water systems to speed hot water delivery, reduce water waste and save pumping energy.
The internal thermostatic balancing cartridge automatically modulates flow to ensure a constant temperature in the recirculation piping system. The THERMOSETTER is adjustable from 95°F to 140°F with a locking adjustment knob. An integral dry well holds a slide-in temperature gauge for local indication or a sensor for remote temperature sensing. An optional check valve protects against circuit thermo-syphoning. For applications that require thermal disinfection and protection against Legionella, a self-contained or remote control bypass cartridge is available.
CALEFFI – Creating innovative, superior performance products that help customers live comfortably and economically while softening their impact on the environment.
For more information, email us at or call (414) 238-2360.
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
