EVAPCO Water Saver™ Provides Pre-treatment for Evaporative Cooling Equipment
EVAPCO Water Systems has introduced the Water Saver, a device that substantially reduces water use for evaporative cooling equipment – whether new, or as a retrofit.
Just recently, an Indiana school with a 1,200-ton HVAC system reduced water consumption by 1.5 million gallons/year with the technology.
Water Saver is a capacitive deionization pre-treatment system to improve the efficiency of heat transfer and water efficiency for evaporative cooling systems. The capacitive deionization technology reduces dissolved ion concentrations to lower makeup water conductivity prior to use in evaporative cooling systems. Dissolved ions are removed from make-up water as they are attracted to the charged capacitors.
Water Saver improves water efficiency by increasing operating cycles of concentration; this reduces blowdown and the use of treatment chemicals. Water Saver lowers cost of ownership, provides a 75-90 percent recovery rate, and improves a facility’s LEED rating. The technology is available in nine different configurations.
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
