Introducing Triangle Tube’s New and Improved Tank-In-Tank Technology
Triangle Tube is proud to announce the newest member to the Triangle Tube family of products; introducing the new and Improved Smart 316. The new Smart 316 will supersede the existing line of Smart indirect water heaters and will be available in all current Smart model sizes being available ranging from 30 to 120 gallons.
Many product enhancements and improved manufacturing processes have been incorporated into this new line of high-performance of indirect water heaters including the following:
- 316L Inner Tank – High-Grade stainless steel for long service life
- Acid Pickling – Promotes superior corrosion resistance
- Improved Welding Process – State-of-the-art manufacturing techniques
- Watertight Top Cover – Improved shell prevents corrosion of the outer tank
- Improved Dry Well Quality – All dry wells are subject too pressure testing prior to installation
Along with these product improvements, Triangle Tube is also offering our industry-leading, Good, Better, Best warranty program. The Smart 316 will carry the following residential warranty program:
- Good – Lifetime tank warranty, 1 year part
- Better – Lifetime tank warranty, 2 year part, 1-year labor allowance (registration required)
- Best – Lifetime tank warranty, 6 year part, 3-year labor allowance (registration required, Smart 316 and Triangle Tube Instinct or Prestige boiler installed at the same time plus combustion analysis provided with registration)
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
