Navien Introduces NaviClean™
Navien introduces NaviClean™, Powered by Adey®, the highly recommended magnetic boiler filter designed to work with Navien NHB boilers, NCB-E combi-boilers and any other boiler system up to 199,000 BTU/H. NaviClean protects boiler systems by using a powerful permanent magnet to capture high levels of iron oxide, sludge and debris from the incoming water lines.
NaviClean is designed with bi-directional flow and 360 degree rotational valves, making in-line installations simple enough to be completed in just two minutes. The quick-release trigger and rapid-fit connectors also allow for quick maintenance and reinstallation.
The dirt filtration technology of NaviClean helps extend the life of a hydronic heating system while reducing heating costs, maintenance costs and carbon emissions. NaviClean is available now at your nearest Navien wholesale distributor.
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
