New Thermal Solutions AMP-L Water-Tube Boilers
Thermal Solutions AMP-L condensing boiler and water heater is available in five sizes: 400, 500, 650, 800 and 1000 MBH. AHRI Certified and rated at 97% and 98% thermal efficiency respectively, the AMP-L is available in either a natural gas or propane configuration.
Standard AMP-L models save time and simplify planning. Included at no additional cost are the low water cutoff and high and low gas pressure switch making the AMP-L CSD-1 compliant. Also equipped standard with a strength-adding 3-in-1 vent connector which allows for the use of polypropylene, CPVC or stainless steel venting. AMP-L is capable of up to 200 equivalent feet of vent in AL29-4C, polypropylene or CPVC. Modbus communication also comes standard.
Measuring only 27” wide, the AMP-L easily fits through most doorways and is easily maneuverable in the boiler room. AMP-L stacks two-high without the need for accessory racking systems. Zero side and top clearance optimizes the amount of BTUs AMP-L can offer per square foot.
In addition to standard 10:1 turndown, impressive 300 gpm flow rates and the self-cleaning nature provided by the commercial grade water tube design, an outdoor model is also available at no additional charge.
