Noritz Launches NRCR Condensing Tankless Heater, Combining Hot-Water Recirculation with 0.97 UEF Rating
Two residential models, with maximum inputs of 165,000 and 199,900 Btu/h, offer dual, stainless-steel heat exchangers with category-best, 15-year warranty.
New from Noritz America, the NRCR Residential Condensing Tankless Water Heater Series uses a fully integrated pump to keep hot water close to even the farthest outlet in the home, minimizing the wait and, therefore, the waste of unused potable water down the drain. The Auto Mode on the new NRCR quickly learns household water usage and automatically triggers recirculation-loop activation in line with that expected usage. The correct water temperature is delivered quickly when and where occupants need it the most.
Available with inputs of 165,000 Btu per hour and 199,900 Btu/h, the new NRCR series delivers a premium solution to meet the growing demand for hot-water recirculation. Both models carry an ultra-high Uniform Energy Factor (UEF) of 0.97, while offering the superior durability of dual, stainless-steel heat exchangers. The corrosion and heat-shock resistance of this high-grade material permits an industry-leading, 15-year warranty.
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
