Noritz Upgrades NCC199CDV Commercial Tankless Water Heater
The newly upgraded NCC199CDV Commercial Condensing Water Heater from Noritz America offers an industry-best, 10-year warranty on its redesigned dual stainless steel heat exchangers. Now uniquely produced as a single-piece structure for easier servicing, the new heat exchangers also incorporate substantial improvements in corrosion resistance (100 percent) and heat-shock durability (200 percent).
The re-engineered NCC199CDV also features an industry- leading Uniform Energy Factor of 0.97 and a now fully integrated exhaust non-return valve that speeds and simplifies common venting for up to six heaters without the need for additional accessories. Because the valve is built into the heater, operational safety is assured, and installation time and cost are reduced.
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
