RIDGID®, a part of Emerson’s professional tools portfolio, is celebrating 25 years as the industry leader in pressing this year. The brand first introduced press technolo...
Sanineutral® Neutralizes Condensate, Prevents Costly Corrosion
The SANINEUTRAL® neutralizer kit from Saniflo incorporates neutralizing granules to increase the pH of acidic condensate water produced in residential or commercial applications before it reaches the sewer line.
Condensate produced by boilers, water heaters, air conditioners and other appliances moves through the compact SANINEUTRAL, which neutralizes it to prevent the corroding of drains and sewer systems – damage that could otherwise prove extremely costly to repair.
SANINEUTRAL can be used in two main scenarios. The first is without a pump, where the acidic condensate simply needs to drain through gravity. The second is in conjunction with a condensate pump, such as the SANICONDENS BEST.
Taco Hydroflo Pump Solutions has opened a new state-of-the-art facility in Lubbock, Texas. The site opened on February 21, and substantially expands the operations of the...
Richard Medairos, P.E., Taco Senior Systems Engineer and Commercial Trainer, was presented the Dan Holohan Lifetime Contribution to Comfort Award at Taco Comfort Solution...
