Taco 006e3™ Provides High-Efficiency Hot Water Recirculation
The 006e3 is one of the newest models in Taco Comfort Solutions’® 00e® Series of high-efficiency, ECM-powered circulators. The infinitely-variable, wet-rotor circulator is designed specifically to make installation and operation of domestic hot water recirculation systems easier and more efficient.
With the same quality and reliability that installers have come to expect from Taco’s 00e line, the 006e3 has a dial to select from three performance curves to best match the application, and a setting selection guide to make the choice simple. The whisper-quiet, permanent-magnet ECM motor uses up to 85 percent less electricity than conventional pumps of the same size.
Whether used in a new construction hot water recirculation system with dedicated return lines, or in a retrofit application where water is returned via the cold water line, installation of the 006e3 is easy. The pump’s compact design is ideal for tight spaces, and multiple connection options are available. The circulator is double-insulated so that a ground wire is not necessary, and a three-color LED indicates status. Taco’s SureStart® technology also automatically unblocks and purges air from the line.
For more information, visit www.TacoComfort.com .
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
