Taco 4900 Series™®Magnetic Dirt Separators
Taco Comfort Solutions’® new 4900 Series magnetic dirt separator provides dual-action dirt separation for closed loop hydronic heating systems.
Both hydronic component lifecycle and efficiency are improved with the use of an effective dirt separation system. Taco’s 4900 Series magnetic dirt separator utilizes a powerful, 13,000 gauss magnet in addition to patented PALL ring technology.
The 4900 Series magnetic dirt separator efficiently separates microscopic particles including dirt and magnetite from hydronic fluid with minimal pressure loss. The unit is easily blown down (cleaned) by opening a valve at the bottom of the vessel.
Available sizes range from ¾” to 2” NPT and from ¾” to 1-1/2” sweat. The unit’s maximum operating temperature is 250°F and maximum pressure is 145 PSI.
For more information, visit www.TacoComfort.com
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
