Taco Introduces the New, 007e ECM High-Efficiency Circulator
Taco Comfort Solutions has introduced the new 007e ECM circulator, offering the equivalent performance of the legendary 007 combined with high-efficiency ECM technology that uses up to 85% less electricity and requires no programming. The new 007e affirms Taco’s commitment to ECM technology and their ongoing development of high-efficiency heating components.
The 007e also features the innovative BIO Barrier®, which protects the pump from contaminants, and the SureStart function, which automatically frees locked rotor conditions and self-purges air.
The 007e is ideally suited for hydronic systems zoned with circulators or zone valves. Its compact size and additional convenience features such as dual electrical knock-outs, 6” stranded wire leads for easy wiring, Integral Flow Check (IFC®), and double insulation – no ground wire required. The nut-grabber feature on the flanges makes installation quick and easy. The optional two-way flange model provides universal fit to any flange position.
The 007e even alerts you to its status with convenient LED displays – orange for normal operation and white for SureStart mode. With Taco’s new, feature-rich 007e, hydronic installers can now enjoy high-efficiency ECM technology at a great value.
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
