Taco Offers PF Series Plate & Frame Heat Exchangers
Taco Comfort Solutions’ PF Series plate & frame heat exchangers are ASME designed and constructed. Computerized product selection greatly simplifies the process of choosing the correct heat exchanger for the required application. The compact size of PF Series heat exchangers, along with ease of servicing and Taco dependability, make it an ideal choice for a wide range of commercial applications.
Models with operating pressures of both 150 and 300 psi are available. With flow rates from 50 to 7,000 GPM, PF Series heat exchangers are capable of handling a wide variety of system requirements. Connection sizes from one- to 20-inches are available, with glue free, clip- and snap-on nitrile or EPDM gaskets.
An aluminum or optional 304 stainless steel OSHA shroud are available. Many different applications are possible, including economizer free cooling, ground source heat pumps and freeze protection isolation, campus heating and cooling and pressure zone isolation.
For more information, visit www.TacoComfort.com.
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
