RIDGID®, a part of Emerson’s professional tools portfolio, is celebrating 25 years as the industry leader in pressing this year. The brand first introduced press technolo...
The Perfect Mix from Caleffi
Packed with exclusive features, the new 520 Series TANKMIXER™ quick-connect kit is the perfect mixing valve solution to maximize capacity of modern, high-efficiency (HE) water heaters and minimize installation time.
Everything needed for fast installation is available in the kit, including a cold water cross with check valve, flexible pipe and press, sweat or NPT fittings. With a minimum flow rating of 0.5 GPM, TANKMIXER delivers stable temperature to today’s HE fixtures. Connecting a recirculation circuit is easy with the integral inlet port on the cold water cross and a tight hot water close-off prevents recirculation line temperature creep to protect pump’s aquastat service life. Made with anti-scale polymer materials insures stable temperature control and long life.
CALEFFI – Creating innovative, superior performance products that help customers live comfortably and economically, while softening their impact on the environment.
Taco Hydroflo Pump Solutions has opened a new state-of-the-art facility in Lubbock, Texas. The site opened on February 21, and substantially expands the operations of the...
Richard Medairos, P.E., Taco Senior Systems Engineer and Commercial Trainer, was presented the Dan Holohan Lifetime Contribution to Comfort Award at Taco Comfort Solution...
