Watts Introduces iDROSET™ Static Balancing Valves
Watts is pleased to introduce the iDROSET™ CSD Series of static balancing valves for hydronic heating and cooling systems.
iDROSET balancing valves offer contractors unprecedented speed and ease in balancing a hydronic system.
- Using patented flow measuring technology, iDROSET is the only static balancing valve that lets you set and read flow without any additional tools.
- The valve features a large, easy-to-read gauge that continuously indicates flow without the need to actuate a bypass circuit.
- A simple twist of the ergonomic hand wheel sets flow and can be locked when the desired flow rate is set.
For more information about iDROSET, visit the product page on Watts.com.
Comments by Vanilla
St. Paul Catholic Church Sings Praises of Weil-McLain SVF Boiler
Armstrong Celebrates 90th Anniversary
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Offers Ideal Pressure Boosting Solution
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
