Watts has announced its “Fast Track to Labor Savings” eLearning campaign with dozens of bite-sized modules on Watts Works Online (many available in Spanish and French), d...
Watts has announced the addition of cold expansion fitting tailpiece connections (PEX F1960) for the LFMMV and LF1170 mixing valve series. The addition of PEX F1960 union tailpieces allows Watts to continue to offer a wide range of tailpiece options for these point-of-use and point-of-source thermostatic mixing valves, which also includes threaded, sweat, PEX, CPVC, press, and push-to-connect options.
Connections are available in ½” and ¾” sizes.
For more information, go to Watts.com.
Bradford White Corporation, an industry-leading manufacturer of water heaters, boilers and storage tanks, will highlight its latest commercial offerings at the Mechanical...
Rinnai’s RCW Series commercial boilers are delivering sustained, high efficiency water heating performance at 2150 Condos in Toronto, marking the first installation of th...
