Melroy Plumbing & Heating, Inc.
6537 Baltimore National Pike, Baltimore, MD 21228
Contact: Lance Bent
Phone: (410) 747-0900
Website: https://www.MELROYS.com
Profile
"We Provide, You Decide, MELROY Makes it Right!" We serve and install most plumbing, heating, cooling, and hearth products. Our people are highly trained and certified; no matter what system, what problem you have, Melroy will get your comfort needs met. We are a manufacturer rep for A.O. Smith, State, and American water heaters. We sell Lennox, Slant/Fin, Peerless, Columbia, Weil-McLain, Burham, and other boilers. Master licensed in the trades and certified in building analysis and performance; we save you money! We don't just fix or replace, we make it right. Commercial or residential, the savings are real.
Services
Plumbing, Heating, Cooling, Hearth products. Building analysis for efficiency and conservation. Combustion tests with reports. Factory startup of oil and gas combustion and electric fired equipment. Consultant for proper application of products new and existing. Hydronic: Radiant, Gravity, Water, Steam. Steam injection water heaters. Forced air for cooling or heating. Air and Steam Balance. Process piping. Chimneys. Drain Cleaning. Co-generation equipment installer for commercial operations.
Case Study
Church
Challenge
Problem, damage due to storm flood destroys a six boiler caravan of St Timothy's church/school.
Approach
Identify and provide low price for insurance payout. Build new to prevent repeat occurrence. Identify waste in old design and correct flaws. Install state of the art combustion and controls for peak 96% AFUE.
Solution
Melroy installed 2 new condensing boilers with 5 to 1 turn down ratios, using outdoor air for combustion. Included outdoor temperature reset control to save fuel & minimize overheating & short cycling & an outdoor t-stat to change a "constant on" circulator pump to intermittent outdoor temp control. Turned an $80,000 budget into a $50,000 budget by aggressively pursuing better vendor prices and leaving old boilers on site and donating time for charity. Closed off outdoor air filtration & a wasteful 20" square flue. The old system was so bad that when it tried to save money by only using one or two boilers the remaining standby boilers acted like reverse heat exchangers wasting heat up the flue. Estimated savings over 50% conservatively. Melroy backs this up with proven results. There are many other buildings like this. As a professional Master in many trades and certified in building analysis and performance we have the potential to save customer thousands of dollars if properly repaired and re-engineered. Do a customer a real favor, make it right. Don't just fix or replace; improve the customer's bottom line. Commercial or residential the savings are real. - Lance Bent
