Shane A Foster Plumbing and Hydronic Heating
249 Broadway, Union Beach, NJ 07735
Contact: Shane Foster
Phone: (732) 264-5811
Fax: (732) 264-5811
Profile
Our company is located in central New Jersey. We specialize in steam and hot water systems (baseboard, radiant, radiators, etc.). We also work on plumbing repairs, remodels, and renovations. Fully licensed, bonded, and insured.
Case Study
River Road
Challenge
Customer wanted to remove his underground oil tank and switch to natural gas (which was in the home already).
Approach
After completing a detailed heat loss for the building, we recommended a Triangle Tube modulating/condensing boiler. We also recommended an indirect water heater for potable hot water, but the direct-fired unit was less than a year old.
Solution
The customer had the tank removed. We removed the old boiler and installed the new with all new valves and safeties. We also installed a chimney liner for the existing water heater. We than filled and tested the system(checked with a combustion analyser). The system is quiet, heats great and I look forward to a large fuel savings for the customer. The above was an example where replacement made sense. This is not always the case. Please call my company and let us help you make the right decision for your home or business.
