Here are ratings for the Erie radiator from Jarecki Mfg Co Ltd. They were based in Erie, PA and their radiators appeared in issues of Domestic Engineering in the 1890s.
Thanks to Gerry Gill for sharing this Mouat Vapor Heating System proposal from the early days of steam heating. Note the nine-ounce setting on the relief valve. You don't need high pressure to heat a building.
Brian Roberts & Paul Yunnie compiled this document that contains beautiful vintage advertisements and illustrations of radiators from the mid to late 1800s and early 1900...
This document contains the story of Herman W. Nelson, founder of the Herman Nelson Corporation and the Moline Heating System (a vacuum-vapor heating system).
