Here are ratings for the Erie radiator from Jarecki Mfg Co Ltd. They were based in Erie, PA and their radiators appeared in issues of Domestic Engineering in the 1890s.
This excerpt is from The Ideal Fitter (1922). You'll find indirect radiators (both steam and hot water) within basement ductwork. Often, there is a connection to outside air, and warm-air discharge to floor- or wall grates in the rooms.
Brian Roberts & Paul Yunnie compiled this document that contains beautiful vintage advertisements and illustrations of radiators from the mid to late 1800s and early 1900...
This document contains the story of Herman W. Nelson, founder of the Herman Nelson Corporation and the Moline Heating System (a vacuum-vapor heating system).
