Here are ratings for the Erie radiator from Jarecki Mfg Co Ltd. They were based in Erie, PA and their radiators appeared in issues of Domestic Engineering in the 1890s.
One of the earlier gravity-hot-water-heating devices. Water would stratify in the horizontal main, with the hottest water rising to the top of the pipe. It left the tee and flowed to the radiator though the tee's top tapping. Cooler water from that radiator entered the same tee though the side tapping. Interesting things happen when you add a circulator to a system that has these tees. Thanks to Gerry Gill for finding and sharing the patent.
Brian Roberts & Paul Yunnie compiled this document that contains beautiful vintage advertisements and illustrations of radiators from the mid to late 1800s and early 1900...
This document contains the story of Herman W. Nelson, founder of the Herman Nelson Corporation and the Moline Heating System (a vacuum-vapor heating system).
