Taco’s innovative pump technology now includes its SKV Series SelfSensing Vertical In-Line Pumps. Designed to deliver superior efficiency, reliability, and ease of use, t...
Introduction of MagnaClean Commercial™ Brings Vital Protection Against Iron Oxide Sludge to Large Hydronic Heating & Cooling Installations
As contractors become all too familiar with the damaging effects of iron oxide sludge on today’s high-efficiency commercial hydronic heating and cooling installations, the need for a solution has been growing. ADEY® Professional Heating Solutions is answering that need with the introduction of the MagnaClean Commercial™ Magnetic Filter range to the North American market.
MagnaClean Commercial’s unique, patented magnetic filtration system starts to work immediately upon installation, removing virtually all of the suspended iron oxide that collects in hydronic heating systems. “The removal of iron oxide is facilitated simply by the flow of water through a central magnetic core, which is populated by a series of magnetic rods inside the canister,” says Dr. Neil Watson, ADEY Global Technical Director.
By removing sludge from the system, MagnaClean Commercial restores peak performance and decreases maintenance costs over the life of the system. It also offers a solution for the most common complaints in commercial hydronic systems, including poor system circulation, blocked system pipes and radiators, and excessive system noise.
R.W. Beckett Corporation announces that Thermo Products and its industry leading brand of Thermo Pride products are joining the R.W. Beckett family of companies.
Watts has announced the launch of its "Step Into The Trades" campaign, designed to bridge the gap between sneaker culture and skilled trades. Customers can log into or cr...
