Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered b...
Armstrong Fluid Technology has enhanced its Fireset™ Horizontal Split Case (HSC) pump line with two new technologically advanced models.
Featuring a tilted parting design to maximize efficiency by minimizing turbulence at the impeller eye, the new 5x4x17F and 6x5x12F pumps are ideal for installations that require between 500 and 1,000 USgpm. Compatible with both electric motor (50 Hz and 60 Hz) and diesel engine drivers, the new Fireset™ HSC pumps offer a variety of features:
The Armstrong line of Fireset™ HSC Pumps offers a performance range of 500 USgpm to 3,000 USgpm
SFA SANIFLO USA, a division of Group SFA and a leading global manufacturer of above-the-floor macerators, grinders, drain pumps, lift stations, and condensate pumps, has ...
U.S. Boiler Company introduces its ALTA OneVent System, a simple and safe solution that enables common venting of up to four ALTA high-efficiency boilers. Designed to exp...
