Ideal for Domestic Water & Light Industrial Use
Armstrong Fluid Technology announced that its popular Design Envelope (DE) 4380 Vertical In-Line pumps are now also available in Stainless Steel. Ideal for domestic water and light industrial use, these pumps are certified for safe drinking water systems to the NSF-61 and NSF-372 standards.
The new DE Stainless Steel Pumps can also be used in many light industry petroleum and chemical applications and offer the advanced Design Envelope solutions which includes DE Permanent Magnet (DEPM) motors, Parallel Sensorless Pump Control, built in Wi-Fi connectivity, touchscreen control and optional Pump Manager capability.
The new Stainless Steel DE pumps offer:
The DE 4380 is available in six models ranging from 1 to 2hp, supporting performance levels from 10gpm to 1185gpm flow, and 10ft to 75ft head. It is designed for continuous low pressure circulation, including – water circulation, cooling towers, fountains, irrigation, spraying systems, condensate return, filtration and many other applications.
