Carbon reduction policy is now the norm for the Northeastern States. Renewable low-carbon and zero-carbon energy sources are being aggressively pursued. Among them, solar...
Coffee with Caleffi™ Hot Water Recirculation Systems Thursday, July 20 12 noon CDT
There’s more to designing a domestic hot water (DHW) recirculation system than just adding another pipe and circulator. John Siegenthaler, P.E., a favorite guest speaker to the webinar series, will describe the objectives and benefits of recirculating DHW systems including simple single loop systems, and multi-branch systems. He will explain the concept of temperature-based flow control in recirculation systems, and thermal balancing. John will conclude by showing an example of how unique products such as the Caleffi ThermoSetter™ valve provide intelligent, safe, and energy efficient operation of multi-branch recirculation systems.
You'll learn:
→ What are the benefits of domestic hot water recirculation systems?
→ What can happens in domestic hot water systems that do not have recirculation provisions?
→ How should plumbing designers determine flow rates in a domestic hot water recirculation system?
→ What are the advantages of temperature-based control of recirculating domestic hot water systems?
→ How can a variable speed circulator be used in a domestic hot water recirculating system?
A seasoned industry leader and visionary, John shares his over 35 years’ experience in the understanding and proper application of water-based engineering principles and passion for teaching with our audience. He is a regular contributor to industry publications Plumbing and Mechanical, PM Engineer and HPAC magazines.
Coffee with Caleffi™ technical training webinars are free and intended for contractors, designers and wholesalers. Register by clicking the link below and following the instructions. After registering, you will be immediately forwarded a confirming e-mail containing log-in details for attending the webinar.
When training time comes, grab a coffee and learn more about Caleffi’s innovative products and how they can add value to your work. All attendees are emailed a Certificate of Attendance following the event.
By submitting your webinar registration, you are consenting to email communications to keep you up-to-date on industry news. Please note that your personal information is respected and NOT shared externally.
Taco Comfort Solutions has partnered with Contractor Rewards, a free program designed to reward professional contractors, plumbers, builders, and remodelers for buying th...
Armstrong Fluid Technology has announced that its popular three-part webinar series “Building Envelope and the Impact on the HVAC System” is now available in its entirety...
