Navien Features NaviLink™ Wi-Fi at ASPE
NaviLink™ is designed to support remote access for all Navien tankless water heaters (NPE series), combi-boilers (NCB-E series) and gas condensing boilers (NHB series) through the new NaviLink Wi-Fi control and mobile App. Navien’s most recent innovation, a Wi-Fi control called NaviLink™, is now available through Navien’s select wholesale distribution network.
Now, smart phone and tablet owners will be able to control temperatures remotely, access usage data, receive diagnostic notifications and remotely activate recirculation when paired with the HotButton™ accessory - an industry first. NaviLink will be able to report and monitor diagnostic data through the companion App along with error code notification.
NaviLink is capable of reporting the following information for added comfort and peace of mind: DHW and Space Heating set temperatures, Current DHW Temperature, DHW Flow Rates, Inlet Water Temperature, Total DHW Consumption, Average Firing Rate, Cumulative Gas Consumption, and On Demand activation tracking.
With the integration of NaviLink Wi-Fi connectivity a whole new level of control and comfort can be achieved with Navien’s products never before seen in our industry. Navien continues to lead the way in innovation for the plumbing industry that consumers and installers have come to expect from the leader in condensing technology. Existing installations may require the purchase of a new main PCB and front control panel. www.navien.com
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
