Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered b...
Navien, the leader in high-efficiency condensing technology, has introduced the new NFC series stainless steel fire tube combi-boilers at AHR 2019 in Atlanta, GA. This innovative product will be available in two sizes, NFC-175 (175,000 BTU/H) and NFC-200 (199,900 BTU/H), with enough heating input for up to a 3,500 square-foot home and continuous domestic hot water supply for up to three bathrooms. Best applications include retrofits and new installations in single-family homes, multi-family houses, and light commercial buildings.
The new Navien NFC combi-boiler models come with a patented in-house designed and manufactured heat exchanger, Low Profile Burner for ease of service, advanced controls offering intuitive user navigation, a built-in DHW module (pump, flat plate heat exchanger, 3-way valve, mixing valve, water adjustment valve and auto water fill valve), common venting capability up to 8 units, cascading capability up to 16 units, and built-in hardware to connect up to 3 zone pumps without a need for additional external controllers.
Other NFC combi-boiler features include:
Available in March, each unit will ship with 16 accessories including a NaviClean™ magnetic filter, an isolation valve kit and an NFC primary loop manifold for easier installation.
Navien also unveiled the new NFB-C commercial fire tube boiler. Shown in two sizes NFB-C-301 (299,900 BTU/H) and NFB-C-399 (399,900 BTU/H) the NFB-C uses the same patented stainless-steel fire tube technology from the NFB series released in 2018. The commercial fire tube boiler features an industry leading 15:1 turndown ratio, 91.7% thermal efficiency, BACnet or LonWorks to BMS communication capability and top and bottom water piping connections.
To learn more about the Navien NFC series fire tube boilers, visit NavienInc.com.
SFA SANIFLO USA, a division of Group SFA and a leading global manufacturer of above-the-floor macerators, grinders, drain pumps, lift stations, and condensate pumps, has ...
U.S. Boiler Company introduces its ALTA OneVent System, a simple and safe solution that enables common venting of up to four ALTA high-efficiency boilers. Designed to exp...
