Taco Comfort Solutions Domestic Water Booster Pump Packages
Taco’s new and improved, fully-integrated domestic water booster systems are the ideal pressure-boosting solution for multi-residential and commercial buildings.
Each system comes with a range of features and benefits exclusive only to Taco, including an integral controller in every drive that offers complete built-in redundancy and minimizes downtime. A grooved pipe coupling between pump and header permits greater design flexibility and minimizes installation and maintenance time. Also, an electrical mechanical disconnect allows isolation of an individual pump and drive, enabling the system to continue to run while maintenance is performed. And every Taco Booster Package comes with Taco’s TSL (Taco Smart Logic) Constant Pressure programming.
Available in Simplex, Duplex, Triplex or Quadraplex configurations, offering capacities between 125 to 2,000 GPM. Each booster pump package is fully customizable with Taco’s easy-to-use Booster Configurator App. Taco Booster Systems are factory assembled, performance tested, UL labeled, NSF listed and backed by Taco’s technical support team.
For more information, visit www.TacoComfort.com.
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
