Taco Introduces Hot-LinkPlus-e™ ECM Recirculation System
Hot-LinkPlus-e by Taco Comfort Solutions® offers high-efficiency, intelligent domestic hot water recirculation ideal for retrofit applications. A dedicated return line is not required.
The HotLinkPlus-e combines a 006e3™ ECM hot water circulator with Taco’s Hot-Link® Valve and Smart Plug Instant Hot Water Control® in one easily-installed package. The Hot-Link Valve, installed at the building’s furthest water fixture, sends cooled water back to the water heater so hot water lines remain hot.
The 006e3 circulator that comes in the Hot-LinkPlus-e package uses up to 85 percent less electricity than a conventional circulator. It has three performance curves to best match the application, and a setting selection guide to make the choice simple. The Smart Plug learns hot water usage patterns and delivers hot water when it’s needed, reducing energy use and extending the life of the water heater.
The entire package is compact, making it ideal for tight spaces. Multiple connection options are available. A temperature sensor is included.
For more information, visit www.TacoComfort.com
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
