REHAU, a global leader in polymer-based mechanical and plumbing solutions, is pleased to announce the appointment of Tim Greer as the new Academy Training Manager for its...
Targeted for specific U.S. regional distribution partners, Uponor is launching TotalFit™ — the professional-grade, engineered polymer (EP), push-to-connect fitting solution that provides greater value for residential projects with the same versatility and speed as brass push-to-connect fittings.
Designed for use with PEX, PE-RT, CPVC, and copper piping systems, TotalFit is ideal for service repair, maintenance, remodels, and retrofits for potable hot-water and cold-water distribution piping systems in single-family homes, townhomes, apartments, and condominiums.
“Uponor has a strong leadership position in residential plumbing with AquaPEX® pipe and the ProPEX® fitting system,” says Aaron Stotko, director, Segment Marketing, at Uponor. “Now, with TotalFit, we are expanding into the plumbing repair, maintenance, and renovation segments with a high-quality, reliable fitting solution from a brand professionals trust.”
Taco offers the HS Series Horizontal Split Case Pumps – engineered for superior efficiency, durability, and ease of maintenance. Designed to maximize power savings while ...
Rinnai America Corporation, a leader in innovative, energy-efficient tankless water heaters, has launched a nationwide advertising campaign designed to educate homeowners...
