Weil-McLain® Introduces Advanced, Energy Efficient Stainless Steel Vertical Firetube Commercial Boiler
New State-of-the-Art Boiler Line Features Industry-Leading Thermal Efficiencies, Contractor-Friendly Controls, Durable Design for All Commercial Applications
Hydronic comfort heating leader Weil-McLain® now offers its most advanced commercial stainless steel boiler. The new Stainless Steel Vertical Firetube (SVF) features industry-leading thermal efficiency up to 97.1%, unrivaled ease of installation and maintenance, the intuitive and user-friendly Unity™ control system, and Weil-McLain boiler design reliability and longevity.
“The SVF boiler line was developed with the contractor in mind and utilizing extensive market research and testing to help shape design and functionality,” said John Miller, senior product manager with Weil-McLain. “The result is firetube performance, perfected. The new SVF showcases the quality, durability, serviceability and innovation that contractors have come to expect from Weil-McLain, and demonstrates our commitment to industry-leading hydronic heating performance.”
Available in 750 and 1100 models, the SVF line features a clover-shaped stainless steel fire tube heat exchanger for best-in-class corrosion resistance, a new and bold exterior look, and simple, user-friendly controls to make installation and operation easy. With superior thermal efficiencies, the SVF line offers cost savings and energy efficiencies that could allow owners to qualify for local utility rebates, if available.
The unit meets all market-driven bid specifications, and is designed for most heating needs including applications in schools and other educational facilities, public institutions, healthcare buildings, offices, hotels, multi-family, churches and more.
Time-saving installation features including heavy-duty roller casters for improved maneuverability in confined spaces, industrial-grade leveling legs, an end-shot burner design requiring only 18 inches overhead space, and the advanced Unity control set-up wizard.
“The Unity Controller is designed to reduce installation and set-up time for contractors, simplify boiler system design for specifying engineers, and improve control interface commonality and communication across the entire Weil-McLain high efficiency boiler line,” said Miller.
For ease of service, the SVF features a hinged cover plate with quick access to the burner and fire tubes for simple heat exchanger wash-down with no need for additional disassembly, and an open back panel design with no side access required for service. The unit also features a removable and replaceable condensate base.
Other key features include:
- 70 to 2,0000 MBH compatibility
- 160 psi working pressure
- Natural gas or propane fuel options
- Modbus communication with BACet/Lonworks compatibility
- Low NOX · Full line of venting options
The SVF also is ideal for applications calling for a cast iron boiler complement, and joins the Weil-McLain family of boilers that includes the industry’s widest selection of high-efficiency gas and oil-fired boilers for residential, commercial and institutional needs.
To learn more about the SVF Unity™ boilers, visit https://www.weil-mclain.com/products/commercial-boilers or contact a Weil-McLain regional sales office at www.weil-mclain.com/en/weil-mclain/about-us/locations/.
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
