The popular AquaBalance™ wall mount line of combination and heat only boilers from Weil-McLain now feature an energy saving AFUE rating of 95% on the new Series 2 version. The updated energy efficient units combine the warmth of high-efficiency space heating with the convenience of on-demand domestic hot water (combi version) in a reliable, space-saving, easy-to-install package. The units feature the industry’s latest stainless steel, titanium-infused heat exchanger technology, and are ideal for retrofits or new construction in single-family homes, apartments or condominiums.
“The AquaBalance combi units feature an advanced condensing technology to deliver efficient, worry-free space heat and domestic hot water in a sleek, compact design that’s small enough to fit in a closet,” said Mike Boyd, product manager with Weil-McLain. “The AquaBalance Series 2 boilers have been awarded the ENERGY STAR® Most Efficient designation in 2018 - rated to deliver maximum operational cost savings to homeowners and provide qualification for local utility rebates, if available.”
The AquaBalance is now available in 3 sizes (80, 120 & 155 MBH input), in both combi or heat only versions. The impressive AquaBalance 155 size combi-boiler produces a constant supply of hot water up to four gallons per minute (GPM) at 70 degrees Fahrenheit temperature rise. The unit has the power to supply hydronic heat for up to a 2,500 square-foot home and enough hot water to run two showers and a dishwasher simultaneously.
The boilers also feature an aesthetically pleasing design and simple, user-friendly controls making installation and operation easy for contractors and homeowners.
“When choosing the combi version, the AquaBalance streamlines the installation process by eliminating the need to connect a separate boiler and hot water tank,” said Boyd. “Fewer pipes and less connection points translate into reduced set-up time and a more efficient installation.” Other features of the AquaBalance include:
To learn more about the AquaBalance boilers, visit https://www.weil-mclain.com/products/aquabalance-series-2 or contact a Weil-McLain regional sales office at www.weil-mclain.com/en/weil-mclain/about-us/locations/.
