Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered b...
Armstrong Fluid Technology has enhanced its Fireset™ Horizontal Split Case (HSC) pump line with two new technologically advanced models.
The new 5x4x10NF fire pump is ideal for installations that require rated flows of 500USGPM (1890 L/min) at pressures ranging from 55 to 167 psi. This performance range is perfect for applications such as high-rise buildings.
The new 8x6x15NF pump is designed for installations requiring rated flows of 1500 USGPM (5680 L/min) and 2000 USGPM (7570 L/min) at pressures ranging from 54 to 168 psi. This performance range is perfect for medium sized commercial applications such as shopping malls or smaller campuses.
Compatible with both electric motor (50 Hz and 60 Hz) and diesel engine drivers, the new Fireset™ HSC pumps offer industry leading features:
The Armstrong line of Fireset™ HSC Pumps offers a performance range of 500 USgpm to 3,000 USgpm.
SFA SANIFLO USA, a division of Group SFA and a leading global manufacturer of above-the-floor macerators, grinders, drain pumps, lift stations, and condensate pumps, has ...
U.S. Boiler Company introduces its ALTA OneVent System, a simple and safe solution that enables common venting of up to four ALTA high-efficiency boilers. Designed to exp...
