Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered b...
Designed with the “sensor within”, the IPS 4000 series offers a comprehensive control solution that does not rely on remote sensors to optimize the control of any variable flow HVAC system. Featuring patented Best-Efficiency staging in a headered configuration, the IPS 4000 operates in either a stand-alone mode or networked through the BMS to maximize the performance profile of up to six pumps in 12 zones.
“The IPS 4000 offers building managers energy savings under any operating condition,” said Lex van der Weerd, CEO of Armstrong Fluid Technology. “In addition, choosing a system that does not rely on remote sensors can provide measurable cost savings by avoiding the expense of purchasing and installing unnecessary equipment.”
About Armstrong Fluid Technology
With over 1000 employees worldwide, operating seven manufacturing facilities on three continents, Armstrong Fluid Technology is known around the world as a forerunner and innovator in the design, engineering and manufacturing of intelligent fluid flow equipment. With its expertise in fluid dynamics, heat transfer, variable speed, and demand-based control, Armstrong Fluid Technology leads the fluid systems industry, including HVAC, plumbing, and fire safety in providing the most energy efficient and cost effective solutions to building professionals and owners around the globe.
SFA SANIFLO USA, a division of Group SFA and a leading global manufacturer of above-the-floor macerators, grinders, drain pumps, lift stations, and condensate pumps, has ...
U.S. Boiler Company introduces its ALTA OneVent System, a simple and safe solution that enables common venting of up to four ALTA high-efficiency boilers. Designed to exp...
