Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered b...
Bacharach, a leading provider of HVAC-R gas instrumentation and monitoring solutions, today introduced the new MVR-SC controller designed to seamlessly pair with MVR-300 refrigerant monitors to provide real-time status of refrigerant leaks throughout a facility.
The key functions of the MVR-SC include:
The MVR-SC eliminates the need to integrate VRF leak detection into a BAS controller and the related custom programming expense. By implementing a hybrid Ethernet serial network the MVR-SC simplifies the Modbus integration, provides fast response for fault detection and troubleshooting and is quickly deployed in any size facility.
The MVR-SC monitors up to 100 MVR-300 devices and has an integrated audible alarm. The MVR-SC has an intuitive user interface built on a color, touchscreen display.
VRF systems are being increasingly deployed in multi-tenant building such as hotel, dormitories, assisted living facilities, and offices. The Bacharach VRF leak detection system, which includes the MVR-300 and MVR-SC, improves occupant safety in the case of a VRF system leak.
SFA SANIFLO USA, a division of Group SFA and a leading global manufacturer of above-the-floor macerators, grinders, drain pumps, lift stations, and condensate pumps, has ...
U.S. Boiler Company introduces its ALTA OneVent System, a simple and safe solution that enables common venting of up to four ALTA high-efficiency boilers. Designed to exp...
