Caleffi's DISCALDIRTMAG® Magnetic Separation Line Expanded for Commercial Applications
Caleffi expands its’ solutions to problems caused by ferrous oxide debris within hydronic systems.
Ferrous oxide debris, which is abrasive and often microscopic, is created from the oxidation of iron or steel materials. It can deposit onto heat exchanger surfaces and accumulate in other components including circulators, causing reduced thermal efficiency and premature equipment wear.
The new ASME registered NA546M Series DISCALDIRTMAG® continuously and efficiently removes air and debris that forms in hydronic circuits including the removal of up to 100% of ferrous debris. Non-ferrous debris gets separated out by colliding with an internal element in the flow stream and settling to the bottom of the separator, while the microscopic ferrous debris gets drawn into and captured by a concentrated magnetic field created from a stack of powerful neodymium rare-earth magnets located beneath the flow stream. A blow down ball valve allows easy removal of all captured debris.
CALEFFI – Creating innovative, superior performance products that help customers live comfortably and economically, while softening their impact on the environment. For more information, visit Caleffi’s Web site at www.caleffi.com, email, or call (414) 238-2360.
U.S. Boiler Company introduces the OneTouch control system. Currently standard on the ALTA condensing boiler and combi boiler line, OneTouch dramatically expedites startu...
Rinnai America Corporation, a leading manufacturer of innovative, energy-efficient water heating and home comfort solutions, is now Canada’s top-selling brand for tankles...
