Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered b...
Carlin Combustion Technology, a leader in the production of burners, highlights the EZ-1 Residential Liquid Fuel Burner. This state-of-the-art burner, part of the innovative EZ-Series, combines cutting-edge components with Carlin's proven reliability to set a new standard in residential heating efficiency and performance.
The EZ-1 is designed with HVAC technicians in mind, offering simplified setup and servicing. With a capacity range of 0.5 to 1.65 GPH, it meets diverse residential heating needs while prioritizing energy efficiency. At the heart of the EZ-1 is the Pro-X 70200 Diagnostic Primary Control, featuring a built-in LCD display for real-time burner status updates and easy diagnostics. This advanced control system provides detailed fault history and simple on-screen set-up and navigation, enhancing user experience and troubleshooting capabilities.
Complementing the primary control is the Pro-X 45000 Universal Ignitor, tested under extreme conditions to ensure trusted confidence in any situation. Its robust circuit design and optimized heat management contribute to the overall durability and reliability of the burner.
The EZ-1 Residential Liquid Fuel Burner is UL Listed for use in the U.S. and Canada. The EZ-1's design prioritizes quiet operation, engineered for smooth light-off, clean combustion, and minimal noise, creating a more comfortable environment for homeowners. It features high-quality components, including stainless steel nozzle lines and Suntec fuel pumps with solenoid valves optimized for performance with today's fuels.
Energy efficiency is further enhanced by the PSC motor, which delivers the required torque while reducing energy consumption. The EZ-1 is versatile in its fuel compatibility, designed to work with No. 1 or No. 2 Fuel Oil. Notably, it's also compatible with biofuel blends up to and including B100, showcasing Carlin's commitment to sustainable HVAC heating solutions.
With its advanced features, user-friendly design, and commitment to efficiency, the EZ-1 Residential Liquid Fuel Burner represents Carlin's dedication to innovation and quality in the heating industry. It provides homeowners and technicians with a reliable, efficient, and easy-to-maintain heating solution that meets the evolving demands of today's market.
SFA SANIFLO USA, a division of Group SFA and a leading global manufacturer of above-the-floor macerators, grinders, drain pumps, lift stations, and condensate pumps, has ...
U.S. Boiler Company introduces its ALTA OneVent System, a simple and safe solution that enables common venting of up to four ALTA high-efficiency boilers. Designed to exp...
