Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered b...
As plumbing, HVAC and mechanical contractors become all too familiar with the extended costs of maintaining commercial hydronic heating components or system life, the need for a solution has been growing. Adey® answered that need with the introduction of the MagnaClean CMX™ range to the North American market in May 2022.
This easy-to-service range of filters not only protects system equipment — heat pumps, boilers, pipework, and sensors/controls — but also reduces maintenance costs and hours, improves heat transfer, heat output and efficiency, saves energy, lower clients’ utility bills, and reduces carbon emissions.
Why wait for system issues to arise?
The MagnaClean CMX range is the latest innovative extension of Adey’s market-leading MagnaClean® range of filters, offering a new and unique way of capturing both magnetic and non-magnetic debris by combining powerful neodymium magnets with a range of high quality, 5-50 micron spun-bonded filter cartridges, and needle-felt bag filters.
These cartridge-and-bag filters also act as passive deaerators, encouraging the release of dissolved air and gases from the system water, which can then be vented via the automatic air vent that is included with each of the three side-stream filters within the range: the MagnaClean CMX Nano™, Midi and Maxi.
SFA SANIFLO USA, a division of Group SFA and a leading global manufacturer of above-the-floor macerators, grinders, drain pumps, lift stations, and condensate pumps, has ...
U.S. Boiler Company introduces its ALTA OneVent System, a simple and safe solution that enables common venting of up to four ALTA high-efficiency boilers. Designed to exp...
