Taco has introduced new, compact HS Series Horizontal Split Case Pumps, which take up 50% less floor space while offering the same superior hydraulic performance. Precisi...
Adds “Armor” to ductile iron backflow preventer valves
FEBCO has announced the addition of the ArmorTek™ advanced coating system to its ductile iron backflow preventer valves. This advanced patent pending technology provides three layers of protection to create an effective barrier, dramatically increasing resistance to corrosion.
According to Cameron Rapoport, Backflow Product Specialist for FEBCO, “When epoxy coating is breached, iron exposed to water corrodes, and in some cases, bacteria can create accelerated microbial-induced corrosion, or ‘MIC’.” The ArmorTek three-pronged corrosion protection solution provides:
ArmorTek technology is a unique field-proven, multi-layer approach to corrosion protection for iron valves. For more information, go to https://www.watts.com/armortek.
Navien, a leading manufacturer of high-efficiency comfort solutions, has announced the launch of its new NAA Series air conditioner, further strengthening the company’s r...
Merino Energy, a San Francisco-based climate hardware company built to make buying and installing a heat pump as efficient as the technology itself, today emerged from st...
