Introducing Pipelounge™ by Malco HVAC Copper Piping Support System
Pipelounge by Malco 3
Malco Tools, one of the nation’s leading solution developers and manufacturers of high-quality tools for the HVACR and building construction trades, introduced the innovative new Pipelounge™ by Malco support system for multiple insulated copper pipe installations in commercial buildings.
Pipelounge™ by Malco is an innovative HVAC insulated copper piping support system developed to significantly improve jobsite efficiency, saving time and eliminating the need and hassle of installing strut while adequately protecting pipe insulation for the life of the HVAC system itself.
Pipelounge™ is a modular support system designed to securely hold multiple insulated HVAC line sets while allowing for expansion and contraction. Built to reduce material, labor, and installation time, it eliminates the need for complex strut assemblies and excess components.
Designed to hold loads up to 110 lbs per lounge, this system can connect horizontally for wider spans or be stacked vertically in tight spaces without the need for a strut. Brackets are engineered with tough, flame resistant and halogen-free PC/ABS, and are 100% recyclable.
The system is designed for use in both new builds and retrofits to save time and money. In internal studies, Malco Pipelounge™ demonstrated significant time and cost savings with installations 3-4 times faster than traditional strut support systems, representing reduced labor costs and component needs.
“Pipelounge™ from Malco is the ideal solution for contractors who are sick of dealing with strut,” said Rebecca Talbot, vice president of marketing at The Malco Group. “The support system is lightweight, easy to transport and handle, and most importantly, enhances project efficiency with quick setup and minimal effort, lowering the total installation cost. As part of The Malco Group’s growing ecosystem of contractor focused innovations, Pipelounge™ compliments our portfolio of tools and accessories designed to make the trade pro’s job easier and more efficient, every time.”
Patent-pending Pipelounge™ brackets are available in a wide range of sizes from 4.5” (PLMINI) to 24” (PL24) and can be mounted with 3/8” rod and nuts. Joining clips, packers and refrigerant stickers are also available.
