Quilt today announced it has reached 100 Quilt Certified Partners across 26 U.S. states and six Canadian provinces in under one year since launching its Certified Partner...
LG Electronics (LG) will reveal its total component solutions for commercial heating, ventilation and air conditioning (HVAC) rooftop units at AHR Expo 2026 in Las Vegas, Nevada, U.S.A., from February 2-4.
LG’s component business provides integrated capabilities through a comprehensive lineup that includes scroll compressors, electronically commutated (EC) motors, EC fans and drives. Built on LG’s proprietary core technologies, the wide range of core components from LG Component Solutions strengthen the company’s position as a leading global provider in the HVAC industry.
LG’s vertically integrated approach to design and manufacturing delivers end-to-end HVAC component solutions that improve system compatibility, reliability and long-term performance. By sourcing critical components from a single-provider, customers benefit from simplified system design and streamlined maintenance and service through one reliable point of contact. The lineup includes large scroll compressors ranging from 6 to 27.5 refrigeration tons (RT), along with fan motors, EC motors and drives designed for efficient integration in commercial rooftop systems.
The company’s advanced component solutions are proactively aligned with upcoming energy-efficiency and refrigerant transition regulations for commercial and residential HVAC systems in North America, set to take effect in 2029. The U.S. Department of Energy (DOE) has announced stricter standards that prioritize real-world, partial-load operating conditions over conventional full-load capacity metrics – driving fundamental changes in product design. LG offers a complete commercial component lineup across refrigerant types and power supply configurations while maintaining consistent capacity levels. This approach provides customers with greater flexibility during the transition and enables equipment replacement without requiring a full system redesign.
With flexible tandem and trio(1) configuration options, LG’s scroll compressors extend capacity coverage up to 70 tons. A parallel design supports extended capacity and strong efficiency at partial loads, while a combination of fixed-speed and two-stage compressors delivers a 12- to 27.5-ton capacity range suited to diverse commercial rooftop needs.(2)
LG’s fixed-speed scroll compressors incorporate enhanced motor efficiency and refined bearing designs that reduce friction, resulting in reliable performance. Two-stage scroll compressors provide added flexibility by modulating between 67 and 100 percent capacity,(3) sustaining optimal performance as operating conditions change.
Complementing the compressor lineup, LG is also introducing large-scale EC fans designed for increased efficiency and durability. An optimized structure design mitigates airflow resistance, while reinforced fan construction reduces energy loss and supports demanding commercial applications. LG’s proprietary EC motor technology further enhances efficiency, low-noise operation and intelligent system control.
“Our total component solutions empower customers to develop more efficient and reliable commercial HVAC systems while simplifying service and maintenance,” said Kim Cheol, head of the Component Solution Business at the LG Electronics Home Appliance Solution Company. “By providing a broad portfolio of core components from a single, trusted source, we continue to advance customer-focused innovation and demonstrate our long-term commitment to sustainable and forward-thinking HVAC solutions.”
Visitors to AHR Expo 2026 can explore total component solutions for commercial HVAC rooftop units at LG Component Solution booth from February 2-4 (#SU234, Las Vegas Convention Center), directly next to the LG Air Conditioning Technologies booth (Booth #SU223), where showcasing its latest product innovations and an expanded portfolio of advanced HVAC solutions for both commercial and residential applications in the United States.
(1) Tandem or trio compressors are defined as two or three compressors that are connected in parallel to work together within the same refrigeration or air conditioning system.
(2) Product features, specifications, and performance data are based on internal testing and may vary depending on the actual operating environment.
(3) LG Two-Stage Scroll Compressor functions in the dual-mode—one-stage operation at approximately 67 percent for energy-saving mode in moderate environments and two-stage operation at 100 percent for power mode in high-demand conditions. Actual performance and efficiency may vary depending on system configuration, installation environment, and operating conditions.
Rinnai America Corporation, a leading North American manufacturer of innovative, energy‑efficient tankless water heaters, today announced its REHP Series Electric Heat Pu...
New Taco Thermal Energy Storage (TES) tanks play a critical role in shifting energy loads, improving hydronic system efficiency, and helping commercial buildings meet dec...
