Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered b...
Navien introduced three new innovative products in booth 1573 during AHR 2020 in Orlando, FL. The new NPN series non-condensing tankless water heaters, NPE-2 series condensing tankless water heaters and NCB-H series condensing combi-boilers were all displayed at the front of the Navien booth inside the Orange County Convention Center for attendees to get a first look of the industry leading technological advancements within each series.
Available in the NPN-Universal series (indoor or outdoor with vent cap) and NPN-Exterior series (outdoor only), Navien utilizes the technology and innovation that helped make the NPE series the number one condensing tankless water heater in North America in their new non-condensing NPN series, with some new additional features. The NPN series is the first and only non-condensing tankless series to offer NaviTech™ technology that includes a stainless-steel heat exchanger and an advanced stainless-steel burner with the same very low NOx level as the NPE. Both the NPN-U and NPN-E have built-in recirculation control, air pressure sensor, water adjustment valve and mixing valve, and are designed with a pin-to-pin matching configuration for easy retrofit installations.
The NPE-2 series brings the biggest update to condensing tankless water heaters since the NPE series changed the landscape of the industry in 2012. The new features found in the NPE-A2 and NPE-S2 series include a turndown ratio up to 15:1, an upgraded advanced multi-line control panel in plain English for easy set up, and increased 2” PVC venting length. The NPE-2 will continue to offer the high-efficiency features that made the NPE the number one selling condensing tankless water heater, such as dual stainless steel heat exchangers, half-inch gas pipe capability up to 24 feet, cascade and common vent capability, industry leading efficiency up to 0.97 UEF, and the patented ComfortFlow™ recirculation system with built-in pump and buffer tank on the NPE-A2.
NCB-H (high output) series condensing combi-boilers are packed with industry leading upgrades to the popular NCB-E series, including industry leading BTU output on DHW, 15:1 turndown ratio, a more dynamic BTU lineup with added models, greater DHW performance, a new DHW module with flow control, enhanced controls with multi-line text display, increased 2” PVC venting length, easy serviceability with upfront 3-way valve and built-in controls for up to 3 zones.
All three innovations are on display inside Navien booth 1573 at AHR in Orlando, FL until February 5, 2020. To learn more, visit NavienInc.com.
SFA SANIFLO USA, a division of Group SFA and a leading global manufacturer of above-the-floor macerators, grinders, drain pumps, lift stations, and condensate pumps, has ...
U.S. Boiler Company introduces its ALTA OneVent System, a simple and safe solution that enables common venting of up to four ALTA high-efficiency boilers. Designed to exp...
