Watts has announced its “Fast Track to Labor Savings” eLearning campaign with dozens of bite-sized modules on Watts Works Online (many available in Spanish and French), d...
NIBCO INC. is proud to announce that it has filled out its line of press-connect wrot copper fittings with the addition of 10 new fittings in a variety of configurations. NIBCO press fittings are the fastest and easiest way to make pipe connections for plumbing, mechanical and process piping systems.
The PC611 press tee line additions comprise nine new configurations, including 1¼ x 1 x ½, 1¼ x ¾ x 1¼, 1¼ x ¾ x 1, 1¼ x ¾ x ¾, 1¼ x ¾ x ½, 1¼ x ½ x 1¼, 1½ x 1¼ x ¾, 2 x 1½ x 2, and 1 x ½ x ¾.
NIBCO has also added the PC612, a ¾-inch press x press x female thread fitting in wrot copper, suitable for potable water, hot or chilled HVAC and process applications. The fittings may be installed underground.
The NIBCO leak detection system identifies uncrimped connections during system testing. When properly crimped a unique "N" witness mark is clearly visible. The NIBCO® Press System® includes a complete line of fittings, valves, accessories and pressing tools.
These fittings comply with the performance standards of ASME B16.51 and are third-party certified to the IAPMO UPC and PS-117 standard.
NIBCO® wrot copper press fittings, including its newest tees, are proudly manufactured from 100 percent North American pure copper at the company’s Stuarts Draft, Virginia, facility. NIBCO has been manufacturing metal plumbing fittings in the United States since 1927.
Bradford White Corporation, an industry-leading manufacturer of water heaters, boilers and storage tanks, will highlight its latest commercial offerings at the Mechanical...
Rinnai’s RCW Series commercial boilers are delivering sustained, high efficiency water heating performance at 2150 Condos in Toronto, marking the first installation of th...
