Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered b...
Midea has introduced a new Packaged Terminal Heat Pump designed for individually controlled hotel rooms and hospitality environments as well as multifamily residential applications. The all-climate system delivers 100% heating at 5°F and cooling performance up to 115°F, supported by a self-heated condensate misting design that prevents ice buildup in extreme conditions. Operating as quietly as 30 dB(A) and STC up to 31, the PTHP enhances comfort while simplifying property management through intelligent controls and an integrated fresh air system delivering 60 CFM with MERV 13 filtration. The solution helps property owners reduce energy use by up to 75 percent, offering a compelling return on investment without the need for major renovations. With convenient front access and a rotating PCB, the unit offers easy access for any future repair or replacement needs without removing the unit from its sleeve.
Contractors and companies that are interested in becoming a Midea heat pump distributor or learning more about Midea’s heating and cooling solutions should call 1-888-MIDEA-NA (1-888-643-3262).
SFA SANIFLO USA, a division of Group SFA and a leading global manufacturer of above-the-floor macerators, grinders, drain pumps, lift stations, and condensate pumps, has ...
U.S. Boiler Company introduces its ALTA OneVent System, a simple and safe solution that enables common venting of up to four ALTA high-efficiency boilers. Designed to exp...
