The Pennant line of fan-assisted, modular boilers and volume water heaters are among the industry’s most versatile and environmentally friendly commercial systems for hydronic and hot water applications.
Available in seven sizes from 500 to 2000 MBH, Laars Pennant boilers/volume water heaters are fueled by natural or LP gas and deliver efficiency levels up to 85%, with stage firing of up to 4:1, and cascade with auto redundancy. Pennant systems also qualify as low- NOx emission-rated, below 10 ppm.
The Pennant now has a substantial upgrade with its LAARS LINCTM Intuitive Control System. The controls include an auto cascade setup feature that easily configures lead lagging of up to eight Pennants. The color touchscreen home page displays key boiler performance measurements, easy to use and navigate control structure, USB input, easily connects to building automation systems via BacNet and a quick start option among many other features.
Pennants can be vented from the top, or back. They can also be installed indoors or outdoors and racked on top of each other for up to 4000 MBH in a small footprint.
