Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered b...
Phyn and Uponor, the companies behind Phyn Plus Smart water assistant + shutoff and the Uponor Pro Squad, recently announced that its industry-leading water monitoring and leak detection innovation is now even smarter with the introduction of a B2B multi-property dashboard as well as several new features designed to improve the user experience and make homes safer. The device will also be commercially available in Europe beginning next month.
“Since introducing Phyn Plus to our industry just one year ago, several exciting enhancements have been made, further solidifying the brand positioning as the smartest, smart water leader in the residential building market,” says Bill Gray, president, Uponor North America. “And, with the introduction of our multi-property Phyn Dashboard, we have robust tools for builders, and property managers to get smarter about their water use to more efficiently run their businesses.”
SFA SANIFLO USA, a division of Group SFA and a leading global manufacturer of above-the-floor macerators, grinders, drain pumps, lift stations, and condensate pumps, has ...
U.S. Boiler Company introduces its ALTA OneVent System, a simple and safe solution that enables common venting of up to four ALTA high-efficiency boilers. Designed to exp...
