Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered b...
Power-Flow Pumps & Systems; Mansfield Ohio, announces a major expansion to its product offering. In addition to its existing offering of sewage, commercial pond, grinder, cutter and de-watering pumps & controls 1HP thru 50HP, Power-Flo his proud to announce the introduction of; Wet Rotor Circulators (Cast Iron, Bronze & Stainless) 1/25HP thru 1/2HP, Hydronic Expansion Tanks 2 gallon, 4 gallon & 8 gallon, Potable Thermal Expansion Tanks 2 gallon & 4 gallon, Ductile Iron Circulator Flanges, Bronze Isolation Flanges, Residential Sump & Sewage Pumps 1/4HP thru 3/4HP, Base Mounted End Suction Pumps 1.5” thru 20”, Frame Mounted Close Coupled End Suction Pumps 1.25” thru 4”, Horizontal Split Case Pumps 2” thru 16”, standard configuration OR custom designed UL Certified VFD’s and Control Packages FOR ALL of our pump products. Mark D’Agostino; Vice President of Sales & Marketing commented “Though it has been a great deal of work, I am very excited to see Power-Flo Pumps expand to become a formidable player in the US pump & control market. We are certainly earning our new brand pledge- Power-Flo Pumps, Your Power-Ful New Partner For All Of Your Pumping Needs”. For more information, contact Mr. D’Agostino.
SFA SANIFLO USA, a division of Group SFA and a leading global manufacturer of above-the-floor macerators, grinders, drain pumps, lift stations, and condensate pumps, has ...
U.S. Boiler Company introduces its ALTA OneVent System, a simple and safe solution that enables common venting of up to four ALTA high-efficiency boilers. Designed to exp...
