Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered by REMS Press Ring Kits at AHR 2026. The new REMS Press Ring Kits allow contractors to utilize easy, quick-to-connect press fittings in tighter confines that cannot accommodate soldering and brazing, or the standard size of RLS press tool jaws.
The REMS Press Ring Kits are compatible with the RLS 24kN and 32kN press tools. Built from specially hardened steel for a long service life, the REMS kits offer consistent, reliable connections and deliver a flameless, faster alternative to brazing. Engineered to ensure optimal force distribution and ring-to-fitting engagement, all while maintaining exceptional durability, contractors can install confidently and quickly with the REMS kit.
“At RLS we are committed to providing contractors with the tools they need to improve efficiency and labor timelines,” said Susan Labadie, president of Rapid Locking System. “The addition of the new RLS Powered by REMS Press Ring Kits to our product offerings is a perfect example of RLS responding to the continued evolution of the industry and the needs of our customers.
The kits feature a pivoting ring design that is the perfect solution for tight-clearance applications. Difficult install locations, such as behind units, in hard to maneuver mechanical rooms, and the limited mobility of a ceiling space, can all be made manageable with the REMS Press Ring Kits.
Backed by over a decade of proven performance and millions of leak-proof connections installed, contractors can rely on RLS and the REMS Press Ring Kit to press with confidence and finish the job faster.
