Taco’s new LeakBreaker™ is a water heater leak protection device that guards against flood damage from a leaking water heater. It consists of a control unit, a valve with actuator and a sensor.
This resettable, testable protection device can be installed on any style water heater to shut off the incoming water supply, preventing additional water flow to a damaged water heater. The two-color LED light and audible alarm provides constant status of the LeakBreaker.
The unit’s plumb and plug design – with full-port valve and easily-removed actuator - is specifically engineered to permit new or retrofit installation. Components are pre-wired to simplify the installation process; just plug in the
sensor, valve, power supply and/or batteries. LeakBreaker can be tested any time, and then be reset to guard against a future leak.
For more information, please visit www.TacoComfort.com.
